dcp306-21 gasket help
I need help finding the two gaskets that fit on the throttle body insulator/spacer.  Its for an 1983 EA81 HITACHI dcp306-21. The rebut kits come with the spacers but not the gaskets.
Any help would be appreciated.
You could get some gasket material and trace the spacer to cut out your own gaskets. You could also use the tube.
I'm not familiar with the 2nd gens as much so I'm not sure if they're a paper gasket or a metal graphite composite.
I might actually have some gaskets at home, I'll have to check. I have an EA81 sitting around for something someday and it came with a full gasket set. I'd be converting it to TBI anyways so I don't need the carb gaskets.
I'll message back here later today or tomorrow and let you know.
No go on the gaskets. They weren't in my gasket collection.
Is there no results when you search the P/N?
You can use a cereal box to make those gaskets. Done it many times with no problems.
