Replacement ignition lock cylinder
So I have a 98 Impreza and I’m trying to find a new ignition lock cylinder to replace mine. The previous owner left just the tumbler and not the entire assembly. I cannot find the replacement for a 98. I find 97 but not 98. Find every year after as well. I can find the ignition switch just not the full assembly. Any help would be very appreciated. Thank you.
www.car-part.com
If you have a you pull it yard close by, just go in with your drill and drill out the bolts and get the complete assembly.
