August 24, 200421 yr Hey all, I just wanted to know if anyone out there has a working EA81 with working AC in it.. The reason is I was wondering if when you turn the AC on does your main engine fan as well as the AC condesor fan turn on at the same time?????? Thanks this will help trouble shoot my elctrical problem... Joe
August 25, 200421 yr Author Bump-Oh Hey all, I just wanted to know if anyone out there has a working EA81 with working AC in it.. The reason is I was wondering if when you turn the AC on does your main engine fan as well as the AC condesor fan turn on at the same time?????? Thanks this will help trouble shoot my elctrical problem... Joe
August 25, 200421 yr Hey all, I just wanted to know if anyone out there has a working EA81 with working AC in it.. The reason is I was wondering if when you turn the AC on does your main engine fan as well as the AC condesor fan turn on at the same time?????? Thanks this will help trouble shoot my elctrical problem... Joe Yes. All will be clear if you look up the fan wiring schematic. I think the much maligned Chilton maual has one in it.
