92 Legacy - component location, help!
92 Legacy / front drive only
Could anyone give me a detailed location for the Purge Control Solenoid that runs to the Canistor. ( maybe some identifying characteristics)
I see several possible units, but I am not 100% sure. Hard to trace under the manifold.
Thank you!
Try this approach. Find your EGR valve. The metal EGR valve body will have a small black rubber hose connected to it. Follow that hose to where it connects with something. That something is your EGR solenoid. See the boxy little EGR solenoid with the weird little plastic plunger thing sticking out one side?
Your Purge Control Solenoid looks like this, and is set up like this. Trace your little black canister hoses toward the engine until you find one that plugs into a thing that looks like your EGR solenoid. That's your PCS!
