August 29, 200421 yr for the water temp gauge located on the engine?... i know its 1/8" NPT thread, ive been told its at the back left of the engine.. but i cant see it?!.. anyone got a picture?... do you have to take the inlet manifold off to get at it or something?!... cheers:)
August 29, 200421 yr Look at the IAC valve, and then look a lil infront and down. There's two there and I always forget which one is which.
August 29, 200421 yr http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2477.JPG brown one is for the ECU, (one you want to replace) the small one is for the dash gauge.
August 30, 200421 yr Author thanks guys... Mr 777 whre do you get all these fabulous pictures from?! makes things alot clearer:) BTW i need the small, single wire one;) much appreciated..
August 30, 200421 yr I took them when I was swapping injectors, and intake manifold gaskets. I removed the whole intake and cleaned things up and took a bunch of pics
