Odd Clunk
So ever since I got my '93, I've noticed a semi-loud "clunk" coming from the right front wheel area after a hard right turn. It has to be a very hard right, and it only happens after I start turning the wheel back to center, and only when I'm moving forward. The sound is like "tonk!" Sounds like something might be binding up, or snapping back into place, or someting. Doesn't seem to be affecting the driveability of the car, but then again, it's a not sweet sound. Any ideas?
check your sway bar bracketing, those like to come loose some times and make a similar clunk. 12mm bolt, should be pretty tight
Ahh, thank you sir. I will go down and check on it later this morning. Hope it's something as simple as that!
