September 12, 200421 yr Hello all... This question will probably scream loud and clear just how un-mechanical I am, but I am going to swap the ECU out of a 88 DL for use in another Subie, and the mechanic told me just to unscrew it, located near the steering wheel.... I think I have discovered its location, but does anyone have any general advice on doing this? Is it that cut and dried, just open the panel and unscrew? Any advice would be helpful and relieve the stress of doing this probably very easy task. Thanks all, banuru
September 12, 200421 yr ok step by step sorta ...open panel remove mounting things for ecu disconnect the plugs on the ecu put new ecu in place recconect plugs re attach ecu put panel back on start car and drive away thats is if it all works
September 12, 200421 yr Maybe its a no brainer, but I would probably stick disconnect battery in front of all those directions
September 12, 200421 yr ahh cmon.. where is your sense of adventure?? but yeah. all i can say is.. DOH!!!
September 12, 200421 yr Author Thanks everyone, that does help to boast my confidence about doing it. I was also thinking that yes indeed disconnecting at the battery first was a good idea. Thanks again, chat ya later, Banuru
