October 8, 200421 yr I need to know the Final drive ratio of a 1999 legacy manual transmission.... Thanks Cory
October 8, 200421 yr Author I asked you this on nasioc... what trim level? Dont have any specs....if they are diffrent give me all of them i guess the only specs i have is 99 legacy thanks
October 8, 200421 yr http://www.main.experiencetherave.com:8080/subaru_manual_scans/1999_Legacy_FSM/3_Transmission_and_Differential_Section/3-1_Manual_Transmission_and_Differential/MSA5TCD99L147.pdf http://www.main.experiencetherave.com:8080/subaru_manual_scans/1999_Legacy_FSM/3_Transmission_and_Differential_Section/3-2_Automatic_Transmission_and_Differential/MSA5TCD99L172.pdf Remember, despite the fact these scans are from the factory manuals, and "should" be correct, it's always important to verify it, because I've seen lots of errors in the manuals.
October 8, 200421 yr Author Legacy 777 is the bomb...i found out it was a 1999 legacy GT manual so i will check out those pages or if you know based on that trim package let me know cory
October 8, 200421 yr The factory manual says for the 2.5 liter manual tranny, final drive ratio should be 4.111 The GT had the 2.5 liter, so final drive ratio should be 4.111
