crank t bars up
Remove rubber plug under rear seat. Will be one adjustable bolt. Use socket with extension. Best to first wd-40 the threads from the underside if rusty, then jack vehicle up to help lessen tension and adjust. r/PK
(I just used 'wd-40' as a verb)
