October 28, 200421 yr I was just looking at the Soob at lunch, and I noticed a puddle underneath it. So I jokingly said it must be leaking, when I moved it to a different spot to see if indeed it was leaking, and it was. Soooo, I jacked it up and it looks like a drain tube on the passenger side, below the firewall was dripping water or something. What is this? Is it right? My coolant was indeed low, which scares me. I topped it off. But the drippy stuff just looked like h2o. Good thing I looked underneath the Soob cause I noticed I routed the brake line wrong while replacing the half shaft, and the new half shaft wore a hole right down the the steel in the brake line.
October 28, 200421 yr Sounds like the A/C condenser drain tube, its normal, especially with higher humidity. And given your location I suspect that you may have run the defroster this morning? (the A/C cycles when the defroster is on) Gary
October 28, 200421 yr Author Yes, I ran the defrost all the way to work. Thank you very much for the info. Sounds like the A/C condenser drain tube, its normal, especially with higher humidity. And given your location I suspect that you may have run the defroster this morning? (the A/C cycles when the defroster is on) Gary
October 28, 200421 yr deffinitly an a/c drain tube, comes down infront of the fire wall, on the psngr side
