What wheels fit on 1993/94 legacy AWD automatic wagon?
Hi,
Can anyone out there help me with a list of possible donor cars for rims for my 1993/1994 2.2 AWD automatic stationwagon? there are not many subarus around here and I was going to try to get some alloys for my car. I have a set of steel rims on at the moment (for the winter).
I have read something about peugeot 505s etc. Is this true?
Thanks in advance.
best regards
Dusan
Any 5 x 100 wheel with at least 40+mm of offset should fit. The larger the wheel you get, the more offset you will need.
I don't know about the peugot wheels you're talking about. They sound more like something that would fit the older 4-lug subarus.
well those are for the older generations of Subarus but as Legacy777 says anything that is 5x100 with the 40mm offset is fine but make sure it's 14" or larger unless you have the larger calipers and rotors then 15" or larger is recommended cause the 14's don't fit over the brakes
