November 5, 200421 yr This alarm is the one on which the arming and disarming "chirp" can NOT be disabled. If the alarm remote doesn't work, I thought that you could turn off the alarm by pressing the "reset" button under the dash while turning the ignition on and off three times. Well, I tried it, and it didn't work. The alarm kept wailing away. Any help would be appreciated. Thanks.
November 6, 200421 yr Is there a Valet mode? Do you know where the "brain" is? If so go ahead and pull all the fuses you can find attached to it. If you have a starter kill then it will be a little bit harder. If this is the case just find where the brain wire meets your starter wire off the ignition and bypass it by removing the wires and putting the two wires back togetehr so they form one. Use a wire nut. Any more questions please feel free to ask or check out www.the12volt.com
