November 8, 200421 yr For 99 Legacy (2.2l MT) to drain the block - two plugs must be unscrewed using hex bit. Does anyone know hat size is it? 10mm or 12mm? Also is this the best way to drain the block? Thanks in advance. Alex
November 8, 200421 yr Like this href=http://www.ultimatesubaru.org/forum/showthread.php?t=24460 But DON'T tell the EPA
