November 10, 200421 yr I think someone had something about power windows before but did not read it. Sorry. My power windows suck. I have a 92 Loyale 4wd 5 speed. The driver side window is the only one to work. The front passage barely goes up and I dont even mess with the back ones any more, you basically have to push them up. Is it the motor for the windows or what? I'm a newbie. Please help.
November 10, 200421 yr it's in the switches, same thing here on my 88 gl-10 , i changed all the bad switches with good ones , also spray some lube around the window motors
November 11, 200421 yr Author it's in the switches, same thing here on my 88 gl-10 , i changed all the bad switches with good ones , also spray some lube around the window motors Im not the best mechanic at all. But what are these switches. Are you talking about the switches on the door to move the windows up and down? If not where are they located. sorry im kinda a newbie.
