Frank B Posted November 21, 2004 Share Posted November 21, 2004 Ok, my 86 hatch has a bad hesitation/stumble. Did the usual tune up, filters, carb cleaning/rebuild, checked timing. But it still has a bad stumble. The EGR dash light is on, but there doesn't appear to be an ECU anywhere? What triggers the EGR light? Before I go and rip off all the emissions, what components are the usual suspects? I can hear odd noises coming from the air baffles going to the exhaust, but disconnecting them didn't seem to help. 86 4WD 4 speed EA81 Hatch Link to comment Share on other sites More sharing options...
Skip Posted November 21, 2004 Share Posted November 21, 2004 Few questions, couple answers "But it still has a bad stumble." Most often caused by a bad accelerator pump in the carb. A can of Seafoam (avail. at any quality auto parts) has been known to work miracles - takes a hundred miles or so though. "The EGR dash light is on, What triggers the EGR light?" The EGR light is triggered by a mileage counter (60 kmi). To reset it look above the fuse box after removing the trim panel. There will be three odd colored connectors. Two will be plugged together one will be loose. Unplug the two and plug the other into the proper end. SHAZAM no EGR light. "but there doesn't appear to be an ECU anywhere?" Normally there is not one on this model. Look for a 02 sensor Remember - - No 02 = No ECU "I can hear odd noises coming from the air baffles going to the exhaust, but disconnecting them didn't seem to help." Well now you have a open can of worms - this generally means the reed valves in the AVS system are toast. (try a search for "AVS" you'll see what I mean) If not dealt with the baffles as you call them (silencers) will melt and plastic will be ingested by the carb - - not pretty this may have happened and is the reason for the stumble. Use an electric torch and look down the carb throat for signs of black plastic debris. Note this can also lead to jammed open throttle plates not a good thing - BTDT Hope this helps somewhat. Link to comment Share on other sites More sharing options...
Frank B Posted November 21, 2004 Author Share Posted November 21, 2004 It's all coming back to me now....slowly.I'll reset the EGR light, no problem. Rebuilt and cleaned the carb, new acc. pump, adjusted float, etc, etc so I dismissed that as a culprit, but I'll look again. Thanks Skip Link to comment Share on other sites More sharing options...
