subpennyman Posted December 25, 2004 Share Posted December 25, 2004 My 93 Loyale has several problems-but the killer is- it starts and then dies! If I pour straight gas down the throat of the carb, it will stay running until my small supply of gas is used up! I have fuel pressure getting to the Injector because when I went to remove the clamp, fuel started easing out and as I pulled the line back further, it started to stream out! I disconnected the 4 pin connector at the injector body and attempted to take voltage measurements- 2 pins had approx 6 volts dc. Not knowing what specifically to do with the information or where to go from here, I decided to put everything back together and go inside and think about it! But before I closed the hood, I tried to start it one last time- the thing started and stayed running! It was very rough- and thats when I realized I had never tuned it up since we bought it new-it has 155,000 on it. Well, I tuned it, plugs, wires, cap, rotor, air filter (it was plugged pretty good)! Now I am back to my original problem! It starts and then dies! I am looking for any help you can offer- I have access to one of those computer analyzers- but I cant find the mating connector on where to plug it in to! The dealer says its under the dash- drivers side- but we are not finding it. Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted December 26, 2004 Share Posted December 26, 2004 You didn't mention that you replaced the fuel filter? Did you? If not, you should. You could try disconnecting the battery for about a hour, then hooking it back up.(This will caused the computer to relearn the car.The computer might be used to no air, or something) I've done that (after a tune up, on a toyota)and it started up. Good Luck [HTi]Johnson Quote Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 No, I haven't mentioned the fuel filter; I haven't replaced it and didn't think that it could be causing the problem because of how the engine started to run almost flawlessly after I did a voltage check with an analog voltmeter on all 4 pins at the harness connecting to the fuel injector. I will consider replacing the fuel filter when stores reopen tomorrow. I must admit that I have never heard of disconnecting the battery for an hour to allow the computer to relearn the car-I'll go try that right now; and then I'll ponder some more the ramifications of performing voltage checks :could this in some way have discharged a capacitance or reactance charge buildup and allow things to operate normally? Would you know where the connector is locatred on the car for plugging in the computer for running diagnostics checks for an "On engine light" Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 26, 2004 Share Posted December 26, 2004 are the clamps to the intake loose, any unplugged hoses. wire to the MAF loose? Quote Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 I haven't done any work under the hood in 14 years, so no to the loose clamps, I'll look for hoses that may have come off- but what is a MAF and where is it located and what does it do? Thanks people, Sub. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 26, 2004 Share Posted December 26, 2004 its the mass air flow sensor, its located on the air box where the intake hose clamps to. normally when this is disconnected, or the hose is disconnected, the car will start and run for about 5 seconds then die Quote Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 Miles Fox...Thanks- I had no idea that such an animal even existed! Could I get a little more help on its location-though? I know where the carb and the duct work that runs over to the passenger side of the car and the air filter are located- is it on this duct work somewhere? Is it a vacuum or electrical device? I'll check it out when the sun comes up out here in Tacoma, WA. Thanks again- Sub. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 26, 2004 Share Posted December 26, 2004 on the airbox there is a round piece with a black box on top where the clamp fits to. this is the MAF, it has a black wide connecor to a wire with a funny clip. Quote Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 Miles Fox- Thanks, I should be able to find that in the rainy daylight. Can you tell me where the computer connector is located for reading the "engine" codes? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 26, 2004 Share Posted December 26, 2004 under the hood there are a pair of green connectors and black connecotors. you plug the green connectors in to read the codes, and the black connectors to clear them drop the plastick kickpanel from the dash and you will see the led on the front of the ecu. you only need to drop the panel down a few inches to see in the usmb repair manual there is a writeup for reading codes Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 26, 2004 Share Posted December 26, 2004 under the hood on the driver side firewall there are a pair of green connectors and black connecotors. you plug the green connectors in to read the codes, and the black connectors to clear them drop the plastick kickpanel from the dash and you will see the led on the front of the ecu. you only need to drop the panel down a few inches to see in the usmb repair manual there is a writeup for reading codes Quote Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 Things are Still Broken!!! I have left the Battery disconnected for 14 hours and checked the wires to the MAF Sensor- ok. Car starts and then dies- pouring raw gas don the carb throat will keep it running! Sub. Quote Link to comment Share on other sites More sharing options...
