January 3, 200521 yr The Chilton's I have is very vague, and I didn't find anything terribly useful searching. Where is this diagnostic connector I need to jump to read trouble codes? -=Russ=-
January 12, 200521 yr Author Bump. All I need to know is where in the car the diagnostic connector is, and where I read the codes (some places say the check engine light, some say the O2 sensor light on the ECU). -=Russ=-
January 12, 200521 yr Bump. All I need to know is where in the car the diagnostic connector is, and where I read the codes (some places say the check engine light, some say the O2 sensor light on the ECU). -=Russ=- The connector is on the computer wiring loom on ea81s, i presume its the same for ea82s. You read the codes off the o2 sensor light, same deal.
