Ugly noise from left rear quarter, and the right way to fix it. .
OK, my car got jealous of all the attention I have been paying to other cars lately, and started making an ugly "grinding" kind of noise from the area of the left rear wheel. I jacked her up and took a look, found nothing broken, and the brakes and berring check out fine. I slathered a bit of lightweight oil on the top of the strut, and on all the rubber bushings (two rods coming from the center to the wheel, and the one going forward = 6 bushings). That fixed it, but I was wondering: What is the "correct" lube for these joints, and how often should they be lubed?
I'm suspecting these answers will be "a light grease" and "when they complain". . .
Am I wrong? Is this listed somewhere? Was this a freakish occurance?
OK, I'm gonna guess that either I'm right, or no one else has had this happen. . .
Oil and rubber don't generally mix. If anything, I'd use a silicone spray. Or a silicone-based grease. Petroleum makes rubber rot over time.
