'95 Legacy blower fan noise
The heater/blower fan in my '95 Legacy wagon is making noise like the bearings are shot. Naturally, it's worse when it's freezing cold outside (every day recently). It still works but the noise is annoying. How hard is it to change? Other thoughts/comments/ideas?
Mike
Easy to change and I have a good one if you need it. Look up under the glove box and you will see the fan. 3 nuts and a connector hold it in.
I guess you have a lot of use on your fan. I had one, that stopped working as the brushes wore out. It checked good with the multimeter, but was shot.
Pull it and hook 12 V to the connectors. That will let you see the fan work.
It is easy to drop the glove box which gives you better access. Just flex in the sides and pull the hinge screws.
Later, Larry
If you need the fan send me an email. Lmdew@hotmail.com
