removing door panel 96 outback sport
If its the same basic set up start by removing the power window switches (be very carfule and start from the back there is a clip on the back that breaks if you aren't carfule and looks like crap once its broken) then just use a large flat head screwdriver and start prying it back from the bottom. Once you have all the clips undone lift straight up and it should come out if i remember all that right.
