January 24, 200521 yr To all, Especially legacy777.....i am really contemplating the neutral switch.....currently i have the nuetral on the ecu wired through my clutch pedal switch telling it when it is in neutral or not....this is working well...it only allows me to start the car when the clutch is depressed, and also it makes the clutch disengage the cruise control.... If i wire up the neutral switch from the transmission i will lose all of those features..... What is the benifit of running the ecu through the transmission and not doing it like i have done it???? Really want to know Thanks all Cory
January 24, 200521 yr The benefit of running the ECU's neutral signal to the transmission neutral switch is that the ECU will get an accurate reading of when the transmission is in neutral. The switch on the clutch is meant to be used as the starter interupt, not the neutral switch. It sounds like you wired both the neutral switch and the clutch interlock system up to the switch on the clutch, and wired the cruise to the other switch on the clutch. The reality of it is that the car will probably run fine with the setup you have now. There may be some minor weirdoties....but it should run fine. Does everything run fine now?
January 24, 200521 yr Author The reality of it is that the car will probably run fine with the setup you have now. There may be some minor weirdoties....but it should run fine. Does everything run fine now? Car runs fine....now that we got the clutch pedal smoothed out....just wondering the major benifits of changing this over since i would need to think of ways to get the cruise to disengage with the clutch and how to get the car only to start with the clutch in it does this on its own the way it is wired now....... i just want to make sure the work i would put into it to wire it the other way is worth it.....thanks for your help as usual josh Cory
January 24, 200521 yr Welcome CoryI think it wouldn't be too bad to wire up properly....but you have some sort of non-standard setup right?
January 25, 200521 yr Author Welcome CoryI think it wouldn't be too bad to wire up properly....but you have some sort of non-standard setup right? Standard as compared to?? other subies??
January 25, 200521 yr Author a non-subaru setup....custom job yeah custom job....i should take a picture for you.....give me a day or so
