1988 Justy heat tube??
That is called a preheat tube.
Most carbuerated cars need &/or have that to prevent icing of the carb's throat during warm-up and to allow it to generally run better at lower temps.
(keeps fuel/air mixture more volitile at a higher temp)
Fuel Injected cars don't need them because the computer can accomidate low temps in other ways.
The solenoid you refer to may be a form of vacuum motor on the air cleaner snorkel.
The motor could be controlled by a vacuum signal from a solenoid.
when some thermal control senses low ambient temperatures.
If you want to see if it is working, remove the fresh air tube
to the snorkel.
Look inside the end of the snorkel with a flash light.
The vacuum motor should be connected to a flap
via a control rod.
This flap is raised by the vacuum motor to divert
the flow of air from the fresh air tube to the
heat tube you speak of.
Start the car on a cold day, the flap should raise
thus causing the carb to injest the preheated air.
So, I see.So can anyone explain why my Justy overheats If I wait at stoplights/ trains/ or any idle for more than a couple of minutes? This started happenening after my friend broke the tube while trying to unsmash it(so we ended up pulling it). We also cleaned the carb and nothing else. Anything? Thanks again.
