February 5, 200521 yr Lost power in my 97 Outback.... Lights are flashing.....lost my remote fob.... What can I do???? stclara@wpa.net
February 5, 200521 yr Your post is a little vague. What do u mean lost power? Electral power, engine power? What lights went on? Im just a ********************* kid but if i were u i would look through all my fuses and see if any of them poped if it has something to do with keyless entry.
February 5, 200521 yr StClara, Welcome neighbor (see my location) here is a web site describing your security system http://www.cars101.com/subaru/keyless.html#code%20alarm As I see it this should work. Overriding the Alarm when you have lost the remote Open driver's door. Turn ignition key to 'On' Press and *hold programming button* in (see diagram, button under dashboard) After 15 seconds the the door locks will cycle 3 times. Exit programming mode by releasing Programming button under dashboard and turning key to off.
