February 10, 200521 yr Just had my wheels aligned and decided to stray from the play-it-safe factory settings by running some negative camber in front. Stock is 0 front, -1.0 rear. I have changed the front to -0.40", which is as far as it will go with standard components. This is just past the -0.30" tolerance. Toe is 0,0 all round. Holy smokes! This has made such a big difference to the handling. The car scoots around corners without any understeer. Even full throttle acceleration will not get it to push the nose wide. Fantastic! I would strongly recommend this simple, cheap mod to anyone looking for a little more excitement from their Subaru. Keep the tyre pressures even, front to rear. Running low rear pressure, as I have done to compensate for understeer in the past, can make the rear feel a little loose when combined with the negative camber. Suspension and tyre size are all stock.
February 10, 200521 yr I run pretty much -1.0 degree of camber all the way around, and it does make a huge difference in how the car handles. Your tire wear shouldn't really be affected. I've been running those settings for a couple years now, and haven't had any problems. I do tend to rotate my tires about every 3000 miles though. It helps prolong tread wear.
February 10, 200521 yr Author I am still amazed that only half a degree can make such a big difference. Josh, did your extra camber come from lowering or have you installed after-market camber bolts?
February 10, 200521 yr It came from lowering more then likely. I was going to install camber bolts in the rear when I first lowered it, but I really didn't need to. The guy at the alignment place, loosened the strut bolts, wiggled it around to where I wanted, and then tightened them back down. Right now, I have the whiteline adjustable lateral links, so I pretty much have an infinite amount of camber/toe settings for the rear.
February 11, 200521 yr It came from lowering more then likely. I was going to install camber bolts in the rear when I first lowered it, but I really didn't need to. The guy at the alignment place, loosened the strut bolts, wiggled it around to where I wanted, and then tightened them back down. Right now, I have the whiteline adjustable lateral links, so I pretty much have an infinite amount of camber/toe settings for the rear. Sup Man?? I meant to ask where'd you get your Lowered Springs??? I'm having a good time finding some! Also I noticed you were from H-Town.. I'm from the SW Alief area! But live in Alaska for now.
February 11, 200521 yr Hey, How's it going. My springs are whiteline control lowering springs. I got them from teague's auto www.boxer4racing.com I ended up waiting quite a bit for them. Hopefully, MRT, whiteline's distributor out of Australia has gotten better. You may want to give Dale a call at Teague's auto and see if he can still get them, and waiting time. Wow, that's a pretty good jump from Houston to Alaska. I actually grew up most my life in Seattle, moved to Pennsylvania to go to college, moved to memphis for work, and now here in Houston. I live around the galleria area right now. So how do you like Alaska?
