February 28, 200521 yr I know I should know this, but I need some reminders. I think the freeze plugs are located in the heads, two on each side. Am I right; are there others? Thanks.
February 28, 200521 yr If nobody answers first, I will check later. BTW, if you are home and bored, I am making one last trip to Everett PAP. Leaving now. Pat
February 28, 200521 yr I think the ones in the head are the only ones (because I have not seen others on the block) I may be wrong tho.
February 28, 200521 yr Author You are a glutton for punishment; hope you brought your foul weather gear. good luck. If nobody answers first, I will check later. BTW, if you are home and bored, I am making one last trip to Everett PAP. Leaving now. Pat
February 28, 200521 yr You are a glutton for punishment; hope you brought your foul weather gear. good luck. umm yeah i suspect he is addicted to suby punishment... and as far as weather gear... take another look at his screen name... he is used to being all wet behind the ears.. ehhehe
