remote lock question
I came home the other night via Taxi and as I walked up my front steps I clicked the lock on the remote for my '99 Forester. To my surprise the horn honked and the 4-ways flashed. Normally only the 4-ways go off (no horn).
To other '99 owners, when you lock with the remote which happens
1 horn + 4 ways
2 only 4-ways
Do I have a bad elec connection somewhere?
I think you can program the system to sound the horn or not sound it. It appears you will need to reprogram the system. Check your owners manual for details on doing this.
1 horn + 4 ways
2 only 4-ways
From 2000 Outback Owner's Manual:
Selecting audible signal operation
Using the horn, the system will give you an audible signal when the
doors lock and unlock. If desired, you may turn the audible signal off.
To turn the audible signal off, simultaneously depress “LOCK/ARM”
and “UNLOCK/DISARM” buttons for more than two seconds. The horn
will sound two times to inform you that the audible signal has been
turned off.
To turn the audible signal on, simultaneously depress “LOCK/ARM”
will sound one time to inform you that the audible signal has been
turned on.
Hope this helps........
