March 15, 200521 yr I'm losing brake fluid, and it appears that leaking fittings on my ABS pump are to blame. Anyone have a source for a salvaged ABS pump for my car? Thanks in advance. Green96GT
March 15, 200521 yr Are you getting a warning light? Does it work? Are these fittings able to be tightened with an 1/8 turn of a flair wrench? ABS pumps are relatively, hell no, very expensive.
March 16, 200521 yr Author No "ABS" light, just a brake light every coupla weeks due to low fluid levels. It's pretty clear that there's a leak at one of the couplings. I tried to tighten the couplings, but they won't budge, and given that the housing appears to be aluminum I don't want to torque down on them too hard, anyway.
March 16, 200521 yr Author I sent you a reply to the part out, I've got a good one. Lmdew@hotmail.com Is it a "2E" type? (four tubes in a line coming out of the top)
March 16, 200521 yr ABS pumps are relatively, hell no, very expensive.I've heard this before. Just how expensive are we talking? Let me put it this way: ABS adds how much to the cost of a new car?I haven't been able to find ABS pumps in any auto parts stores.
March 16, 200521 yr That's it. The full part number on the blue tag is: 26731AA200 Additional numbers on the tag Nippon 110 000 30460, in th silver box on the tag is 467-0424 4 lines on top 3 cyclinders between the upper and lower blocks 2 lines coming out the bottom engine side block. If you send me and email I can send a picture or two. Later, Larry Lmdew@hotmail.com
April 16, 200521 yr I have a 1995 Legacy and I am having this exact problem. I have been losing brake fluid for a while and couldn't find where it was going. I finally found the leak in the ABS hydraulic unit. It is part number 26731AA200, which I gather is a "2E". I found some online parts but nothing under $900. It seems like there should be a way to fix a leak for less than $900. Anybody have experience with these ABS units? It is hard to tell where the leak is on the unit exactly. I don't think it is from where the lines enter, though. It seems to be from the side or bottom.
April 17, 200521 yr Author I replaced the unit with a used one I bought here. It's a simple bolt-on job that took me about 45 minutes, then another 1.5 hrs to bleed all the brake lines. Look for a used unit, and good luck!!
