March 18, 200521 yr ok, broke a speedo cable, on an ea81 d/r 5 speed, stock tire size, in 5th gear, high range, what rpm should I be turning at 55 and 65?
March 18, 200521 yr I assume you dropped the 5-speed D/R in? If so then you should be cranking about 2500 for 55, and just under 3k for 65 - 5th gear is a bit hard to approximate, the others are easier. The cable is easy to get at on the tranny side (at least in EA82 cars) - fix it and forget it.
March 18, 200521 yr Tire size is another factor in this equation. Got a GPS unit? That's what I used to help gimme an idea of my speed. Just go with the flow of traffic.
March 22, 200521 yr I know people that've gone 100,000 miles on a broken speedo, nah, just kiddin... just run with the flow until you get it fixed
