Cruise control on a turbo
I need to install a cruise control on my turbo wagon
Does anybody have any expeirence with an
aftermarket model?
These obviously have to have a built in vacuum pump as there is no useable intake manifold vacuum in a turbo.
Thanks for any info reguading a manufacturer.
Possibly could check a cruise equipped turbo car to see what the source of the vacuum is. Then you could use that vacuum pump or whatever it is to adapt an aftermarket system to.
If I knew where to look I'd check my car for it; it has turbo and cruise.
