adjustable coilover question?
im curious what is the actual difference in height people get adjusting them from the first notch to the last notch??
i went ahead and adjusted my coilovers today and i had almost a 2 1/2 inch difference in height, and that was with my 50 lb class 3 hitch bolted on the back as well. the crappy haynes manual says at most its only gonne be like 1 5/8 inches i think.
and btw i learned that it is very simple to do if you leave the shocks on the car, i just hooked my strut compresser in there at the best angle i could and tightened them up and did the twisting crap. had both tires done and back on the ground in a 1/2 hour at most.
man all the way on page 3 lol. i take it nobody has measured before and after they adjust their suspension? took my hitch off yesterday afternoon and noticed a decent difference in height, adjusted my front up a bit as well
jim (66subaru) has them on an 88 gl-10 turbo 4at used-to-be-air suspension, converted to coilover height adjastable
the car sat at 25 3/4" inches on the front, cranking the struts all the way brought it up to 26 1/2. we got 3/4 inch heigt on the front full adjustment range
but also i think the geometry of the knuckle or the lwer control arm may be different with air ride, as the whole rig sits lower than the 2wd to 4wd conversion dl wagon
might be a difference, basically after i took off my hitch i had about 5 inches of clearance from the top of my tire to the wheelwell with the stock tire size
sorry i forgot to mention, my measurements were at the wheel arches in line with the axle nut
ill check for an exact measurement tomorrow when i get on some flat ground, none around here for a cpl miles lol,
