April 7, 200521 yr This video is me testing approach and departure angles. http://www.pixparty.com/adog/index.asp?ptype=v&videoid=3559
April 12, 200521 yr I can't see the video but... What are your angles of approach and departure? A sheet of plywood shoved against your tires and an angle finder will tell the tale.
April 12, 200521 yr A sheet of plywood shoved against your tires and an angle funder will tell the tale. i agree,knowing what exactly the angle gives you more of a ability to brag:brow: at least not without having to show it.
