Carburator assistance needed
First i would like to say hello to all the other subie junkies here as i am a new member.
Ok now for the problem, I have an 82 gl wagon with an EA81 still with the stock hitachi carburator and i am having a "blank spot" in my throttle as i give it a little juice it bogs down from 2,000 rpm to nearly 800 then once the secondaries kick on it comes right back up. i recently removed all the extra vaccuum crapola that i didn't need yet this started happening before i did that. I would like to put a weber on it as well so if anyone has a weber for sale or possibly a trade im interested.
Another thing, i recently aquired a EA71 and want to put the pistons from it into my EA81 any tips on this would be nice.
Thanks
ENIN
I suggest the accelerator pump, it squirts a dose of fuel as the accelerator os pushed down, it just adds extra fuel as you accelerate.
to check this remove the air filter, and look down the primary carb barrel, you should see a squirt of fuel as the accelerator is pumped, but u will need a torch and look to the front right hand side, its below that pipe that points up at an angle
