April 18, 200520 yr I have a 2000 outback and the power windows, door locks, and power seat no longer operate. I have checked the fuse box and didn't find any problems. Is there a relay that could be bad in the power distribution box???...This is very troubling. Thanks for any assistance or expertise you may offer!!!
April 18, 200520 yr Have you checked the fusible links for a problem there? Do you have a test light to check for voltage and not just a visual inspection?
April 18, 200520 yr Author Where can I find the fusable links? Have you checked the fusible links for a problem there? Do you have a test light to check for voltage and not just a visual inspection?
April 18, 200520 yr Where can I find the fusable links? Look in the power distribution box, located on the driver's side of the engine compartment behind the battery
