April 21, 200520 yr I'd like to replace the factory front speakers in my 01 Outback which also has factory tweeters in the window pillars. Are the tweaters fed thru a crossover or do they receive the same signal as the door speakers? My replacement speakers have a tweater included, so not sure how that will workout with the existing tweeters. Thanks, Mike.
May 9, 200520 yr Mike, You can just unplug the tweeters in your window pillar. It's just a clip on the back side of the tweeter. I added the factory ones in (didn't come with the car) and I love the difference in the sound. The higher frequencies are more directional than the lower ones, so a tweeter in your window pillar should give you better sound. The new ones in the door will be pointing in a different direction? What's wrong with 2 sets of tweeter? Good Luck, Glenn 82 SubaruHummer--no stereo anymore... 01 Forester--Non-factory stereo, factory tweeters!
May 10, 200520 yr if you do replace the factory tweeters, i'm interested in the factory ones for the wifes outback
