what are some signs of a clogged cat converter?
i took my xt out for a drive last night and i noticed in 5th gear i went to climb a hill i have climbed many times before, the car was losing speed going up it, never happened before. then as i came down the back side it wasn;t accereration like it normally did. then after a while going downhill it started pulling along pretty good, any thoughts? i know the car does have a exhaust leak around the first cat area. ill be looking at that tomorrow. any insights would be greatly appreciated.
when my cat element came loose and blocked the exhaust, I had NO POWER. I could only accelerate over 35 going down hill. There was also a distinct louc 'whistle' from 'somewhere in the front of the engine'.
I used a rubber hammer to gently tap the cat, and heard the chunks of the element bouncing around. After that I pulled the Y pipe and cat, and really heard it rattling around.
It might run hotter than normal too if the catalytic is plugging. Power loss is usually the one you notice first.
Haven't had one clog on a Sube yet, but the symptoms described above are typical of what you'll encounter.
Another possible sign would be 02 sensor problems - either fault code, or outright failure. Black smoke out the tailpipe (from running rich) could be the result of a clogged cat.
Diagnosing these can be kind of tricky. In my most recent experience, I only discovered the problem by process of elimination. And this was only verified when the pipe was removed. And of course, you can easily destroy the 15-20 year old OEM pipe trying to take it off.
Makes complete sense after the fact, but these can stump you when trying to chase down the problem.
good luck, John
