1999 Forester 2.5 L Knock sensor location
Hi to all,
I have a 1999 Forester and for the past week I have been getting an intermittent CEL with a code of P0325 (knock sensor).
Could someone please tell me where the knock sensor on my car is located.
Is it on the driver side as I suspect?
The only manual I have is a Haynes for a 1998 Legacy and it states that to remove the sensor the intake manifold must be removed first. I see other messages that state it is a 15 to 20 minute job.
If any pictures are available for a '99 Forester that would also be greatly appreciated.
Thanks in advance,
A.J.
Look straight down behind the intake manifold, just to the left of the throttle cables. Its straight down, a 12mm bolt, single wire going off about an 1.25" dia. black sensor.
The connector is harder to unplug than it is to remove the sensor.
Later,
Thanks Imdew for your prompt and precise reply. Appreciate it. Have a good day.
-AJ
