May 17, 200520 yr hi to all does anyone knows if its a good motor oil (10w40), i mean this company product http://www.royalpurple.com/index.html http://www.royalpurple.com/techa/whyrpa.html http://www.royalpurple.com/techrp/summary.html http://www.royalpurple.com/arta/arta.html is it whrilly good as it look like?...... does anyone use this kind of oil for the subaru loyale? i'm using till now castrol 10w40, is this royalpurple better then castrol? (it cost here 1.5 times then castrol), is it worth it? thank you all moshe.
May 17, 200520 yr I have never used it personally but I see it advertised as "high performance" and the local rice burner shop sells it to the kids who like to rev the piss out of their Hondas.
May 17, 200520 yr yes i have heard about it ,i am using amsoil oil just about like it in my 88 dl d/r wagon with 187,000mi , 1 thing i have seen is that it will seep more even after all seals were replaced , royale purple claims better hp, mpg , .also aleast using amsoil it gave me 5-10 lbs more oil pressure , with a after market pressure gauge ,
May 18, 200520 yr Author so...what do you say? it worth ? it will make the engine work better? thank you?
May 18, 200520 yr i think it will ,the cost at first is higher but over a year it all comes out the same 5.95 ea x 4 = 23.80 , change oil every 12,000mi ,change filter every 6,000mi , and of course 1 extra qt for small leaks or burning , or regular oil at 1.79 qt every 3,000mi ,but i am only using amsoil oil right now , which is = to it , now for what grade 20-w50 or 15w -40 ? i guess it all depends on where you live ? hot all the time or pretty cool outside+ use a good filter , wix, ,bosh, mobile1, just my opinion
May 18, 200520 yr i've heard that their oil is supposed to actually increase hp output by decreasing friction.:-\ who knows? it might be true
May 18, 200520 yr yes i heard that to , also a guy with 3 company trucks that was at the store i was buying amsoil at said that his 3 v8 trucks were getting 2-3 mpg more using royale purple , i may try it myself , you can buy it for like 5.50 qt shipped or around that ,
May 19, 200520 yr Royal Purple is awsome.... I won a free case from SubieSport magazine and I love it. Slight increase in mileage. I'd totally believe that it frees up some HP.. best thing is at the gas station, when the guy checks your oil and it's really fresh he says, "dude, your oil looks kind of purple" also, I go atleast 5-6k between changes with it so when you do the math, it's not that expensive... garner
May 19, 200520 yr where is the cheapest place to buy royale purple + shipping , i found it for 5.50 qt includes shipping ,
