lmdew Posted May 29, 2005 Share Posted May 29, 2005 Just finished putting a 95 Impreza 2.2 into a 98 Outback. Both were autos. All worked fine, but the flex plates are different size, by about 1/2" dia. (don't ask me how I fournd this out). You will need to keep flex plate from your Outback and bolt it up to the impreza engine. The Air conditioning mount bracket has smaller mount bolts as well. Keep all the brackets from your Outback. Quote Link to comment Share on other sites More sharing options...
subie94 Posted May 29, 2005 Share Posted May 29, 2005 i take it the 2.5 had h/g probs? have you taken it out for a run yet to test it out? if you did,was there a diff in how much power it has? i've always heard of people doing swaps to put bigger engines in,but never the other way around. Quote Link to comment Share on other sites More sharing options...
lmdew Posted May 29, 2005 Author Share Posted May 29, 2005 Yep, HG were gone. This is the second 2.5 > 2.2 swap I've done. The power loss is very little and you get an engine that will go 300K+ that will not trash itself if the Tbelt goes. Quote Link to comment Share on other sites More sharing options...
tracer46 Posted May 31, 2005 Share Posted May 31, 2005 I just had the same swap (95 Legacy 2.2 into a 98 Outback 2.5) done but found that the 2.2 engine has no EGR valve. Anyone have any suggestions as to what to do? The Check Engine code is that the EGR is malfunctioning. Do I need a different intake manifold so that I can install an EGR or do I need an ECU from a 95 2.2? Any help would be appreciated. Can't pass my states emissions when the CE light comes on. By the way, the car is running just fine. Quote Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted May 31, 2005 Share Posted May 31, 2005 try running the 2.5 intake manifold on the 2.2, i believe its bigger anyway.... might breath better.... Quote Link to comment Share on other sites More sharing options...
tracer46 Posted May 31, 2005 Share Posted May 31, 2005 Is it a straight swap without any mods? Guess I didn't think it would be compatible. Quote Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted June 1, 2005 Share Posted June 1, 2005 im not sure, but if it works let me know, thinking of trying a 2.5 intake on my wagon... Quote Link to comment Share on other sites More sharing options...
