June 8, 200520 yr Depends. If you're getting white smoke out the back of the exhaust like I was, it is most likely the Vacuum Modulator that needs replacing. Easy to fix. Otherwise another problem is seals. Richard
June 8, 200520 yr Depends. If you're getting white smoke out the back of the exhaust like I was, it is most likely the Vacuum Modulator that needs replacing. Easy to fix. Richard yup,i had to replace one acouple yrs back.basically unscrew and screw new one back in.
