Cluster retrofit?
Anybody know if a '97 Legacy Outback guage cluster will "plug and play" into a '95 Legacy? Can anybody out there with an '97 auto Outback tell me if PRND12 shows up in the center of the cluster?
Thanks.
The gear indicator in the cluster was deleted from 2d gen. Legacies sold in US. The cluster housing does have a slot for the indicator, which is a small circuit board with lights and a plug, inserted sideways from the back. But you'd also need the black trim piece for the instruments that has an opening for the indicator. Thus it might be best to get a used Japanese-market cluster, although the indicator itself is available because it's the same as was used on 1993-94 Impreza and then also deleted.
By the way, for 1995-97 Imprezas all the necessary parts are available, new or used. A wiring diagram would be needed to connect the indicator, but otherwise everything is simple. I did it on a '95.
