June 11, 200520 yr just a quick question, I havent done a legacy front wheel bearing, but if they are similar to the EA wheel bearings, then I can do it.. so is the process the same? or do the bearings fit in there different? need to know soon if possible, trying to save sparky some $$ for the trip!! thanks a bunch!!
June 11, 200520 yr It's a bit different. You need to press the hub out of the bearing then press the bearing out of the nuckle. And I do mean press and sometimes heat.
