June 17, 200520 yr Just for people searching around this maybe helpful. Also within a few weeks i will have full write ups on these modifications at www.ccc-store.com/subaru 1. Front and Rear Seats are interchangable between GC8 impreza and 90-94 Legacy seats. Good way to get fold down seats for your impreza. 2. Legacy swaybars will fit impreza's, but not the other way around. Got a beefy one off of a 90ish sedan 3. Rear discs from legacy will swap out drums on an impreza. Need spindles from donor car. 4. Trannys are interchangeable from almost any subaru as long as the final drive matches rear diff...takes some electrical cleverness hope this helps anyone searching...check out my site...its being built
June 17, 200520 yr I hear WRX seats aren't hard to get in, either. Are there Imprezas with pass-through rear seats? I'd like to someday pick up some RS seats for my 93 Legacy, but wouldn't want to lose the folding down capability, although it is heavy and I don't use it frequently.
June 19, 200520 yr Author Just remembered, EJ25 Flywheel and clutch fit 2.2 engines no problem....but you need to keep them matched..(ex. 2.5 flywheel, needs 2.5 clutch and visa versa) Hope this helps people searching
