June 19, 200520 yr Having no experience of anything newer than an 85 Ea 82,can anybody tell me is belt replacement on an EJ 20 T carried out in the same way as the 82,by timing the first one and then rotating the engine a turn for the second one. Thanks in advance . Jude
June 19, 200520 yr the ej22 has one belt. you line the pulleys to matks on the belt itself. there is a hydraulic tensioner that must be squeezed down in a vise and a pin inserted until its installed. as far as the ej 20 i wouldnt know if its single cam or dual cam, but the ej22 is single cams. i have no experience with dual cam. maybe you will want to post in the new gen forum
June 19, 200520 yr Author the ej22 has one belt. you line the pulleys to matks on the belt itself. there is a hydraulic tensioner that must be squeezed down in a vise and a pin inserted until its installed. as far as the ej 20 i wouldnt know if its single cam or dual cam, but the ej22 is single cams. i have no experience with dual cam. maybe you will want to post in the new gen forum Thank you Miles. The info was not for me personally but for someone who wanted to know.I'm strictly Ea 81 and 82 Regards Jude
