June 19, 200520 yr Anyone know where the ecm for my 96 2.2L legacy outback is located? I'm trying to troubleshoot my engine trouble light, which I've found is caused by something to do with the knock sensor.
June 19, 200520 yr Not sure why you are looking for the ECU location, but it is under the "feet" of the front passenger. Lift the carpet and you'll see. There is a metal panel to lift as well IIRC. Commuter
June 19, 200520 yr NorthLight--hope you realize that Subaru ecms don't do the "flashing light" trick. From '95 on you need an OBDII scanner to pull the codes. Bummer, yeah? Anyway, good luck.
