June 25, 200520 yr I found this on ebay... "The Pro Choice Module simply hooks up to your Intake Air Temperature or Coolant Temperature Sensor with Scotch Locks provided." "Add 10-22hp to your power train " I'm nearly jumping for joy.....could someone straighten me out?
June 25, 200520 yr Snake oil pure and simple. If this actually does anything, it probably tricks the Air mass meter into running richer, by tricking the car into thinking it's cold all the time, thereby dumping more fuel into the system. Someone tried the same thing on my wife's 86 Saab 900 S, 16V car. they wired in another coolant sensor inline with the original. If you do buy, best of luck. Later, Todd in Seattle
June 25, 200520 yr its probably a resistor that you wire in line with the maf. pack of 5 costs $.99 at radio shack. its a 'get rich quick' scheme thats common on ebay. if you install one, the car will probably run rich, and then start throwing codes.
