June 25, 200520 yr Will wheels from a newer wrx (2002 +) fit a 95 imprezza 2 door coupe and if so what size tires are needed to make the combination work without hitting anything under neath like strut springs, etc.? Thank you for sharing your expertise.
June 25, 200520 yr Welcome to the USMB! This might help in calculating any differences in tires: http://www.miata.net/garage/tirecalcold.html Not sure what your stock size is but WRX is 205/55/16 IIRC. Steve
June 26, 200520 yr The standard WRX 2005 are the same 5x100 bolt pattern. The STi has changed to 5x114.3? same as SVX.
