July 5, 200520 yr The problem would have to be due to the blower motor is drawing too much current. There may be some shorted windings in it. Replacing the motor should fix that. You could have the current checked to verify the problem.
July 5, 200520 yr You could use a higher wattage resistor also. But the motor is almost certainly teh culprit. PS
