Blower motor resistor keeps failing
My Legacy blower motor resistor keeps failing. Any ideas please?
Gil
The problem would have to be due to the blower motor is drawing too much current. There may be some shorted windings in it. Replacing the motor should fix that. You could have the current checked to verify the problem.
You could use a higher wattage resistor also. But the motor is almost certainly teh culprit.
PS
