July 9, 200520 yr anybody know where I can get new rubber weather strip for 93 legacy? dealers have back ordered for months with no success.
July 10, 200520 yr Well, no, but if you're hoping to cure a leaking sunroof, you would be better off making sure the four drain pipes (in each roof pillar) are clear, and the that the rails which the roof slides in are still sealed to the internal roof pressing. The weather strip on the glass is supposed to allow water to pass by it.
July 11, 200520 yr Author ok thanks, I cleared drain tubes but there are tears in the rubber so it should really be replaced. Thanks
July 11, 200520 yr I’m pretty sure that the outer seal is part of the glass assembly and can’t be replaced separately, but I’d check with a good auto glass shop. For more info on fixing leaky Legacy sunroofs do some looking around over at LegacyCentral. http://bbs.legacycentral.org/viewtopic.php?t=183 Gary
