BRUCEC Posted July 9, 2005 Share Posted July 9, 2005 anybody know where I can get new rubber weather strip for 93 legacy? dealers have back ordered for months with no success. Link to comment Share on other sites More sharing options...
Setright Posted July 10, 2005 Share Posted July 10, 2005 Well, no, but if you're hoping to cure a leaking sunroof, you would be better off making sure the four drain pipes (in each roof pillar) are clear, and the that the rails which the roof slides in are still sealed to the internal roof pressing. The weather strip on the glass is supposed to allow water to pass by it. Link to comment Share on other sites More sharing options...
BRUCEC Posted July 11, 2005 Author Share Posted July 11, 2005 ok thanks, I cleared drain tubes but there are tears in the rubber so it should really be replaced. Thanks Link to comment Share on other sites More sharing options...
All_talk Posted July 11, 2005 Share Posted July 11, 2005 I’m pretty sure that the outer seal is part of the glass assembly and can’t be replaced separately, but I’d check with a good auto glass shop. For more info on fixing leaky Legacy sunroofs do some looking around over at LegacyCentral. http://bbs.legacycentral.org/viewtopic.php?t=183 Gary Link to comment Share on other sites More sharing options...
